v3n0m5
Got a question for you regarding a seadoo I bought as a side project.
Make 1992 sea doo xp
Displacement 587cc
-Rebuilt carbs as per manual suggests
-Compression in both cylinders is 140psi
-Installed new spark plugs
-drained fuel and cleaned tank.(inspected all fuel lines and filters)
Condition:
Out of water the thing fires up no problem. Launch it in the lake and warm motor up. The unit struggles to take off and will only reach 4000rpm. Manual says it should run at 6000 +-500rpm. I checked all my carb settings and it simply will not go over the 4000rpm.
I ran the unit at the 4000 rpm and did a kill on the motor. Following this I pulled the plugs to see what they looked like. After pulling them they had the brown tinge that they are supposed to have.
I'm not sure how to get the thing to run at the specified rpms. The impeller shows signs of wear but I am not sure if that can cause the issue I am having.
Let me know what you think.
Displacement 587cc
Condition:
