Revisit- how does fuel get to the engine 98 GS
Nate and all who helped me get this done. Last post was that engine would run at high rpm but not idle or run at part throttle.
When I overhauled the carb there was no mention of removing the jets. I did not do that but it hit me this morning right out of bed that the problem was that jet. Removed the carb again and got the jets removed. High speed was good but could not see through low speed. Manual calls this the primary jet. I used a needle to gently clear the hole and then cleaned with carb cleaner. When I got it all back together it runs fine. I hooked up hose and let it idle for a minute or two and also punched the throttle a time or two and all is well. I may try to get it to the lake on Monday for a test on the water. This late in the season I hope there will be someone around to save me if it dies in the middle of the lake again. Wish me luck.
