I Don’t know jack
Hello everyone,
I’m seeking help with an issue on my 2007 Sea-Doo GTX (YDV36042F707). The machine is showing an error code P0562, along with a “Low 12V” warning flashing on the digital display, and a “Low Fuel” indicator.
To provide some background, the Sea-Doo has around 250 hours on it and has been gently used over the years. In the past three months, I’ve put over 100 miles on it, although it’s probably only covered about 150 miles in the last four years combined. For two years, it sat unused in the garage. Recently, after a 30-mile run, I took it out again a week later. Within five minutes of starting, it began to beep, indicating “Low 12V” and “Low Fuel,” and displayed an error code. I reduced speed, and when I came to an idle, the Sea-Doo shut off. After five minutes, I was able to restart it and return to the dock.
Assuming the issue was with the battery, I replaced it with a brand new one and cleaned all the connections. I also checked the fuses, which are working properly. However, the error codes, “Low 12V,” and “Low Fuel” warnings persist, with the fuel gauge showing zero even though there is over half a tank of fuel.
After this, I replaced the spark plugs and added three cans of Seafoam to see if bad fuel was the problem. Currently, the Sea-Doo starts and idles poorly but remains idling. I can get it up to about 40 mph for five minutes before it bogs down and will only do 5 mph.
Does anyone have any suggestions or ideas on what could be causing these issues? I’d like to resolve it before taking it to a shop. Any insights would be greatly appreciated.
Thank you in advance!
