Replace Motor mounts?
jasball2
I have a 97' XP and while winterizing it, I noticed that the engine is very loose and moves to the left and right. Is it more than likely the motor mounts? Is it expensive to have fixed, or is it eaisier to buy the parts and do it yourself? Any info would be greatly apprieciated. Thanks
Motor mounts....
It's not ususual for the motor mounts to seperate. If you have a few tools, you can do this yourself. When your removing them, just make sure you note where the shims are and how many are there. That way, you won't have to do a motor re-alignment...........:cheers:
