scubastevehere
Reassembling jet pump using OSD kit with delrin wear ring...impeller is just a smidge too tight, it doesn't spin freely. Thrust washer seems to be installed correctly and seated, also have new shaft and bearings.. The impeller just rubs the wear ring a little too much. Enough that I can spin it with a wrench on the shaft but not by hand. Wear ring seems to be seated thoroughly. What to do? All ideas and help appreciated...
