Ran out of injection oil
franky
Anyone know how long you can run once the injection oil light comes on? I'm assuming it's like the low fuel light. When it comes on you have a little reserve left.
My light came on last week just as I was loading the boat back on the trailer. The boat is a 2004 Utopia 205 with the Optimax 250.
Sounds like it's time to add injection oil? Better safe than sorry. Not something to mess with.
You're probably O.K., I had a Merc. 2-stroke with a similar system, the alarm would sound, the engine will shut its self off before running out of oil.
Lou
What Lou and RF said. The boat should go into idle mode before it becomes a problem. It is a "warning" light. Not a "you cooked your motor" light.
Thanks everyone for you responses.
I was a little concerned after adding oil to the tank and saw that it was bone dry. Thought there would of been a little bit left since the light had just come on.
After further snooping around, I realized there a second tank mounted on the side of the engine still full. That I guess I can call it being the reserve tank. Looking at the size of reserve tank, next time I think I would be ok if light comes on again to run for another half tank of gas before getting into real danger. Of course only do this in emergency situation.
Another thing I learned was once you are into the reserve tank, you must fill the reserve tank first before filling the main tank. Air gets trapped between tanks and oil light will always stays on. Another way to get the air out is to run the engine and remove cap from reserve tank and you can see the tank fill up. Once tank reaches full then screw cap back on and air will be removed. Oil light should come off.
I'm a newbie to jet boats and 2 stoke engines. So I'm learning as I go. Always had regular I/O 4 stroke boats. I didn't think there was much difference between the two, but theres a difference. Jetboats handle so much quicker and plane out so fast but docking is a pain. Also cost of fuel+mixoil is almost double with same size boat and 4 stroke engine with prop. Yesterday I filled up fuel tank $161.00 and purchased 10 liter or 2 1/2 gallon tank of mixoil (Optimax DFI) from basspro for $151.00. This stuff aint cheap!! I would be lucky to get 8 hours on a full tank. Also got my first taste of weeds with a jet boat, lost half propulsion. Limped back to the trailer and cleared the twisted twines out. This was never a problem with my prop boats just shallow water and rocks was bad if I didn't see it coming.
But as the old saying goes "you get what you pay for" and I love this thing. Only had this boat for less the a month and I think I've done more boating this month than I did with my old boat in the last 10 years. And I got a great tan to show for it!!
I'm not sure, but your boat should have a similar oil tank to the others. Once I see that my oil tank is down halfways, I know I can drop a full 1 gallon bottle of oil in. There is no cost difference running your oil tank filled in the top half rather than the bottom half. There is no reason to run it empty. That cost will be much greater than any bottle of oil.
