Radio won’t stay on
Burnhakp
2012 Seadoo Challenger 180. When I hit the power button on the steering wheel for the radio, the radio flashes on for a couple seconds then turns off. Power button on the radio itself doesn’t seem to do anything. Any idea what the issue is? This is the standard Jensen radio that came with the boat. Was working great last season.
Check your ground wires as well find the radio fuse and check. Good chance something’s loose or fuse is blown.
Ground wire would be the two wires hooked up to the negative battery terminal, correct? Where is the radio fuse located?
