question about pump assembly 08 speedster 150
kwiktsi
I am putting the pump back on my boat after being apart for the motor repairs and had a question. Wher ethe pump housing bolts to the pump support, there is the one yellow reducer for the water passage, then there are two other ports which would be the bilge on a ski. There are no o rings in there and I just wanted to make sure I didn't lose anything. I don't see them listed in the parts listing and don't think they're required since the boat does not use the siphon bilge setup, but just wanted to verify, especially since the venturi housing does have o rings in this location. If anyone knows for sure, please let me know! Thanks.
Joe
Most of the boats don't use the bailer system. So... there is a good chance that it's not needed.
With that said... if you have the bailer hoses, and boxes inside... and the tubes are in the nozzle... then put some O-rings in it.
Yeah, no bailer system on it. I figured there weren't any (I usually don't lose stuff like that) but wanted to check. Just odd that the venturi does have o rings on those tubes which are shown in the parts listing also yet the pump housing doesn't. Strange. Thanks for the reply.
Joe
