Question about Oil level....
cdoo97
Just a quick question...2002 Seadoo Speedster 240 Merc EFI...there is a oil fill mark on the large plastic oil reservoir where you add the oil to...it is about half way up the reservoir...is that mark the "fill to this level" mark, or is this the "low" mark? Should the large reservoir be "full" to the top, or just up to this mark 1/2 way up? Thanks for the help in advance!!
Is this the oil tank on the back of the engine... or the 3 gallon tank mounted in the hull?
If it's the tank in the hull... then any level is fine. (as long as you don't run out)
If it's the tank on the back of the engine... it should be full. If the level in that is dropping... there is a leak in the system.
