I decided to pull my engine to do some cleaning and install a couple things. Compression on this is 140 across the board, or I wouldn't waste my time. My plan is to Clean and paint engine, install new Motor mounts, Carbon seal, Have the Supercharger checked out. I was told it was done around 10 hrs ago. The impeller and ring look good. While I'm in there, Riva Thru hull exhaust and intake setup. I know I didn't have to pull it for this, but wanted to do a compete Clean job. May sell it in the summer. Whoever gets it, It will be turn key. What else should I replace or check while it's out. It has 106 hrs on it. Thanks
