mjfarrell2
Sorry for the stupid question, but I don't want to fry my electrical system in my seadoo.  I just acquired a 95 GTS SeaDoo and installed a new Deka Power Sports AGM Battery model ETX16L.  I purchased a Battery Tender Plus model 021-0128 to keep the battery charged when not using.
1st question: Should the battery be removed and disconnected from the seadoo while connected to the Tender Plus while charging? I was told by a local seadoo dealer it was OK to charge the battery while still in the seadoo and connected to the +/- terminal cables of the seadoo. The instructions for the Battery Tender Plus also state this, however, they say if the electrical system is a negative ground system, to connect the negative charger clip to the engine block or heavy gauge metal part of the frame (which there is not a frame).
2nd question: Is the seadoo's electrical system a negative grounded system and does this procedure need to be followed or do I simply connect the positive charger clip to the positive battery terminal and the negative charger clip to the negative battery terminal with the battery installed in the seadoo?
