Guest_User
where`s RJ?
Hey RJ, if you still haven't seen my thread on plugged drain lines, check it on your boat. I believe I've had several 787's (including challneger) blow up on me because of this: the drain line that comes off the rear of the motor (the one that T's in from both jugs) gets clogged. My ski was clogged with sand, my challenger had a little rock in the exhaust pipe fitting. Anyway, this makes your motor run hotter and may be causing your rave problem. It's damn near impossible to pull this off the rear or the engine with the exhaust in place, but also really hard to remove it off the exhaust pipe... Anyway, however you do it, verify that that line is flowing freely and that your exhaust fitting isn't home to rocks or seashells like mine was. Good luck! PS my 4tec project is coming along nicely, ideally I'll be out this summer on it. Maybe I'll even make that trip up to SML like I wanted to![]()
