i have two used seadoo gtx that are exhibiting different problems,
machine 1 will run fine with the choke partially out, but will not run above 4000 RPM without choke slightly out
carbs are rebuilt, all fuel lines are replaced... pop off pressure set at 28 psi initially set 1/4 high speed out tied increase high speed screw to increase fuel flow
machine 2 new engine, carbs rebuilt, pop off valves set to 28/30 psi factory setting on both low speed and high speed screws.
both machines have new plugs, coils and wires and new voltage regulators... the maddening thing is that i see similar posts for both problems but no final solution is ever provided so you can't really determine what finally fixed the problem.
so if any person has the solution to these please respond... if you are just kibitzing then please do not respond unless you have solved a similar problem
