problem with D.E.S.S XP96
rsx25
when i put the key in it will start fine, i heard my problem was the dead switch or something like that. when i start it will bogs for 10 min then be ok, sometimes i just turn it off then on again and it will be fine, everything works great on it, its just anoying, everytime i stop for 10 -20 min it will do it again, they say its a common problem with seadoo, the CDI was change on my seadoo, i think. could this be expensive to get fix?
It sounds like a fuel problem may need to replace gray fuel line if it still has them as they are defective. clean carbs to remove the stuff the gray fuel lines left in the carbs. exelerator pump may not be working and the rave valves may need to be cleaned and inspected. good luck Robin :cheers:
No idea what your looking for!
I guess I'm looking for what it is your looking for. The above quote is from your first post and as much as I'd like to give you some advice, I have no idea what you are talking about. :cheers:
