LikeabossTM
Fitted up my pressure tester tonight and checked the jet pump and oil tank. The good news, the pump held 8 psi for ten minutes.
The bad news, the oil tank wouldn't hold 3psi, I could feel air leaking out of the seam between the upper and lower half of the tank on the port side. Grr! That explains the oil sheen I cleaned up from under the tank.
Oh well, I'll run it like that this season if I don't get to fixing it beforehand, I'll just have to keep the oil level below the seam and crack the fill cap open when stored. Will also have to start collecting bottle caps to use for a low budget plastic weld repair attempt...
