pwgsx
Finally got to take the boat out yesterday to see if everything was fixed that I worked on during the winter. Other than 1 more water leak that I found all the fixes I did were good HOWEVER the same engine that kept giving me a check engine light- it would go into limp mode till I stopped, unplugged the dess key and restarted it. I hooked it up to the can-doo last year and it showed that the oil sensor or TOPS valve was bad. I replaced both sensors top and bottom and activated the TOPS valve with the dess key and can-doo and I heard it click. I did this a few more times and it seems to be working. FF till last night..............
I start the boat- 2004 Speedster 200 , twin 155 N/A engines- on the trailer in the water and am looking for leaks and letting the engines warm up. After a few mins I shut them off and I hear a hiss sound. Puzzled I look around and locate the noise coming from the port engine ( the same one that had the sensor issue or so I thought ). The noise stops. I restart it and run for a few mins, stop and I hear it again. This time I locate air and a light oil spatter escaping from the top valve cover- see pic. I unscrew the oil fill cap and it releases a ton of pressure and the hiss stops. WTF . I am at the end of my rope with patience with this dam thing. What can be causing such pressure under the oil cap in such little time ?? HELP
