hello friends,im a newbie so please be understanding.ok i got a 2000 millenium rx upraded cabrs a a bore.i was a the ocean racing other jetskis having fun, runnig with no problems but when i got in to clean my jetski i messed up,i think,so help me with some thoughts.
1.im idoling normally, using "saltaway" with my garden hose in the hole, turned off the fule nob on the right side of my jetski,pulled out the hose,3 seconds later, it sguts down by it self by fule starvation, witch i have no problem.
2.i forgot to clean/lube the carbs with fogging oil/ spray inside the cyclinders.i turn the fuel back on and start it up, ( with out the hose pluged in thinking this will only be quick,i know so stupid)i cut the fuel off as well as spray the lube down the carbs,it supposed to just bog out but at first it was but 3 seconds later the rpms started going high,then higher,i ran to grab the water hose shovedit back in the hole noticed water was coming out of the proper places after about 5 seconds, it finaly shut down from food starvation.
i say when the rpm was reving high it was probally hiting 4000-5000 rpm.i know it was probally bad....i know, please leave me some insight on the subject.THANK YOU FRIENDS
