Highmaster2
Had a real problem with porpoising on my 99 GSX-L. Even with my 275 lb. butt on it, the trim all the way down and a full tank of gas, it would still porpoise uncontrollably below 40 mph. It was uncomfortable to ride in any level of chop - just wouldn't stay in the water - porpoising constantly. I had already adjusted the VTS rod as long as it would go. If you went WOT from idle, it would jump straight up and just bounce across the water (that's with the VTS all the way down).
I found a threaded sleeve that was 3 inches long. I cut the VTS rod in half. I threaded the two halves to fit the threaded sleeve so that the overall rod length was 1" longer than original. This allowed the VTS to trim lower than normal but still not run out of room.
Now, with the VTS indicator at the mid position, the GSX-L stays stable at most any speed - no porpoising. If the chop gets worse, I can trim down a click or two and the GSX-L stays smooth. Trimmed all the way up, it still trims up enough to run the fastest it has ever run (63 mph on GPS and not even on glass)
Anyway, the fix works for me - It has now become almost as "rideable" as my 2001 GTX 3-seater. Maybe some others can get some benefit from the info.
