Pointhunter75
Fuel pump cover removed, the plate on other side also removed exposing needle and seat. Fresh rebuild wiyh new mikuni needle and seat. Hose on inlet, finger over inlet hole in the carb body and its going to 70 psi and still not popping. Am i doing something wrong?
This is why i have the fuel pump cover off
From sbt:
NOTE: You cannot accurately test with the pump body and fuel filter still attatched to the carb - you MUST disassemble it and test directly into the fuel inlet orifice, where the fuel filter sets. Otherwise you are testing through the pump checkvalves, throwing your readings off, too high. If you have an external fuel pump, this does not apply.
From sbt:
