CasperTFG
2014 Wake Pro 215, bought used this year with 93 hours on it. Have had no issues for the past few weekends put about 14 hours on it but yesterday I was running at high speeds for a longer period of time and got a check engine light with code PO127. I pulled back to the dock stopped opened it up everything looked fine no coolant smoke or unusually high heat under the seat. Once restarted it cleared the error but after driving again at high speeds it re-occurred.
I found a Spark version of the diagnostics manual (assuming the codes are the same) that states -
A bunch of the guys at our marina were helping me out, many of them have been owners for a long time. They concluded that I needed to change out the Exhaust Temperature Sensor. The part is only $28 so I ordered it but now in reading more into the diagnostics I am thinking I may only need to flush the exhaust?
Should I bother switching out the sensor or just try the flush or do both? The new sensor is an after market and I see from many posts there was an issue with BRP sensors so it may be worthwhile to switch it out but I also don't want to muck about where mucking is not needed.
Code:
PCODE: P0127
MODULE: ECM
DESCRIPTION: Intercooler system fault High air intake temperature detected.
CAUSE :Fault detected when the engine is running and stopped.
ACTION: Blocked intercooler water circuit. Clean intercooler water circuit system. Refer to the service manual for more details.
