Spawn_4193
Hi, I have a 2004 GTX supercharged, this ski had a bad oil shut-off valve and the previous owner ran it like that and a bunch of oil exploded out the blow off valve, almost all engine oil. I assume that the gases being unable to escape the engine and building up pressure oil forced its way through the charger seal.
The valve got fixed but it still a bit of oil coming out the blow off, not a whole lot like when exploded, Its more like a mist.
My question is, can this be that because a bad oil shut off valve and no engine gases being able to escape the engine the supercharger seal got damaged and a bit of oil is till is leaking through the charger?
I ask because I don't want to waste money rebuilding the charger and that not being the problem. Also I bought the jetski and have no idea when was the last time the charger got maintenance.
All help will be appreciated, thanks.
