SabotageR1
I have an issue with my 1999 Seadoo GTI. The issue is as followed: She starts and run great, then cuts off for a while and starts up again to run great, only to cut off again. The cut off happens about 20 minute in and takes a while to start up again. She just cranks with no combustion after the shut off. it usually starts with a shut off or two and starts right up before not starting up again some time has passed. The ski had a lot of underlining issues that I fixed but the main issue of cutting off and starting up again seems to still be there. The following are things I've done.
1) All vent valves were replaced so it can't be a vent valve, correct?
2) The rotary valve was completely out of spec, .582mm instead of the .300mm it's supposed to be. I had the cover cut to be in spec
3) I didn't do anything with the carbs because when she's running, she feels like a brand new ski, with power all across the power band, did I make a mistake assuming the carb is fine?
4) When I got the ski, the tank was nearly empty, like one gallon of fuel. I filled it up and added water remover (heet). The ski supposedly only sat for a year with the little gas. I've ran 1/2 the tank so far. Can I rule out the fuel?
5) spark plugs changed twice, so i feel I can definitely rule plugs out.
6) Compressions at 130 each cylinder. I pulled the head cover to change the seal. the jug seals didn't get changed because the walls were warped so I just put it back together. She still ran great after. I think some water may be leaking into the lower end, but I pulled the plugs and cranked the engine and no water comes out. Can I move on with engine being an issue like I assume?
7) This ski love taking in water. I can't figure out from where. New carbon seal kit and it's still doing it. I added a bilge pump, but the question is, can water in the hull affect something to cause a short or something. The water is not high enough to be touching anything so I feel I can move on with the water as the culprit. Am I right?
This is what I have right now, I'll update if I remember more.
