I haven't seen my pistons in two years so can't say what the wash looks like. I'm using 87 octane pump gas with 10% ethanol and the same #80 jets Seadoo used in the 1998 951 calibration. It blows 122psi as of last year.
Stale fuel is not allowed, low quality fuel leads to detonation. I mix nothing with my fuel, I just make sure it's never stale (87 octane with 10% - a few months old is approaching stale, pump it or use it up).
My thought is aluminum pits and carbon out to the edge and perhaps beyond down the skirts into the ring land area is indicative of being too lean (hot pistons can be wear issue too) and this is pretty common due to the pilot holes tend to close up with a slight bit of native corrosion that isn't removed by using conventional solvents and compressed air.
Lean hesitation part throttle is the big clue of being dangerously lean.
Best I can tell I don't need more fuel at this point, judging by the 4-stroke burble I hear from about 2200~2800RPM, it's not pronounced but it's there and hopefully all the fuel I need.
I have to say, the 1st thing to do is restore the pilot holes, this is the root of 99% of hesitation, lean stalling and part throttle detonation issues, IMO.
Best I could tell from my experimentation with my boat, the large venturis don't become dominant till about 70% throttle due to that's where my hesitation would disappear, which was quite pronounced hesitation and lean stalling. If you add fuel using the HS adjusters, I expect you will (and should) see a drop in WOT and not much benefit.
Pilot holes (low speed venturi) are the key.
We use our boat every weekend, I estimate about an hour of engine time is accumulated and almost 5 gallons burned with an average cruise of 50~55% throttle at ~5200RPM and of course a short WOT blast once or twice.
