P-fault codes; all 4-TEC models
seadoosnipe
Premium Member
Premium Member
Are you getting a fault code for your SuperCharged or N/A 4-TEC engine? Even though many of the codes will need you take the ski/boat to the shop for repairs or tuning with B.U.D.S., it's always nice to know what the code means before you take it in. There are a few codes you can take action on yourself. Here is a list of codes:
P0106
Manifold atmospheric presure sensor out of range
P0107
Manifold atmospheric presure sensor or Manifold barometric presure sensor shorted to ground
P0108
Manifold atmospheric presure sensor or Manifold barometric presure sensor shorted to 12V or open circuit
P0111
Intake manifold temp sensor faulty
P0112
Intake manifold shorted to ground
P0113
Intake manifold shorted to 12V or open circuit
P0116
Engine temp sensor faulty
P0117
Engine temp sensor shorted to ground
P0118
Engine temp sensor shorted to 12V or open circuit
P0122
TPS out of range - short to ground
P0123
TPS out of range - short to 12V or open circuit
P01231
Fuel pump shorted to ground or open circuit
P0232
Fuel pump shorted to 12V
P0261
#1 injector short to ground or open circuit
P0262
#1 injector shorted to 12V
P0264
#2 injector short to ground or open circuit
P0265
#2 injector shorted to 12V
P0267
#3 injector short to ground or open circuit
P0268
#3 injector shorted to 12V
P0236
Knock sensor out of range
P0336
Crank position sensor - wrong RPM detected
P0337
No CPS signal, but CAPS signal detected
P0339
Crank signal fault not plausible with cam signal
P0344
Cam phase sensor signal missing
P0351
Ignition coil #1 open circuit or shorted to ground or to 12V
P0352
Ignition coil #2 open circuit or shorted to ground or to 12V
P0353
Ignition coil #3 open circuit or shorted to ground or to 12V
P0461
Fuel level sensor circuit out of range
P0462
Fuel level sensor shorted to ground
P0463
Fuel level sensor circuit shorted to 12V or open circuit
P0505
DLA output stage cutoff memory cuircut or output stage fault or open circuit or short to 12V
P0513
Incorrect DESS key
P0520
Oil pressure switch faulty
P0544
Exhaust gas temperature sensor fautly
P0545
Exhaust gas temperature switch shorted to ground
P0546
Exhaust gas temperature switch shorted to 12V or open circuit
P0562
Battery voltage too low
P0536
Battery voltage too high
P0600
CAN communication problem detected by EMS or MPEM
P0601
TPS learns unlikely or checksum fault
P0602
ECU not coded
P0604
RAM faulty
P0605
EEPROM faulty
P0605
Checksum fault EEPROM
P0608
Sensor 5V power supply short to ground
P0608
Sensor 5V power supply short to 12V
P0616
Starter relay short to ground or open circuit
P0617
Starter relay short to 12V
P1102
TPS adaption failure
P1104
TPS adaption cancelled
P1148
Fuel injector 1,2 or 3 - safety fuel cutoff disabled
P1200
Blow-by valve shorted to ground or open circuit
P1201
Blow-by valve shorted to 12V
P1202
Oil tank pressure switch implausible or blow-by valve still closed
P1517
Compass out of range
P1590
VTS position sensor out of range
P1591
VTS position sensor - low voltage
P1592
VTS position sensor - high voltage
P1593
VTS malfunction
P1607
MPEM fault
P1675
Spare output 1 shorted to ground or open circuit
P1676
Spare output 1 shorted to 12V
P1678
Spare output 2 shorted to ground or open circuit
P1679
Spare output 2 shorted to 12V
P1680
Comminication problem detected by MPEM
P1681
Communication problem - instrument cluster message missing
P1682
Communication problem - EMS message missing
P1683
COM RAM fault
P1690
VTS control up circuit open circuit or shorted to ground
P1691
VTS control up circuit shorted to battery
P1692
VTS control down circuit open circuit or shorted to ground
P1693
VTS control down circuit shorted to battery
P0344, P1200
Burnt TOPS 10A fuse
P1675
Burnt depth gauge or spare 2A fuse
P0353, P0267
Burnt cylinder #3 ignition coil and injection 10A fuse
P0352, P0264
Burnt cylinder #2 ignition coil and injection 10A fuse
P0351, P0261
Burnt cylinder #1 ignition coil and injection 10A fuse
P1680, P1681
Burnt information center 1A fuse
P0616
Burnt Bilge pump, beeper, diagnostic center 3A fuse
P1678
Burnt spare 5A fuse
P0231
Burnt starter, fuel pump 10A fuse
P0600
Burnt MPEM 2A fuse
P1690, P1692
Burnt VTS 7.5A fuse
