heat sensor test
to follow up his boiling water idea, you need an om's tester (the lil horse shoe shaped symbol on a volt meter), and a temperature guage for testing water. you need to look up and find out what temperature the heat sensor closes at. ground the tester on the sensor with the black wire, then touch the red wire to where the plug plugs into it, it should read (1) for no resistance, when the sensor closes (setting off the beeper) there will be resistance and it will measure that on the tester. should go to (0) but either way the measurement dont matter, only whether the sensor closes or not. put the sensor in the water (not the electical end) and begin boiling the water with the tester hooked up to the sensor, when the tester reads resistance or goes to (0) or when it changes, you know the sensor has closed. look at the temperature at which it closed and then find out whether or not its good by comparing to when the temp is SUPPOSED to close it.
hope this helps, confuseing i know but i did my best to explain. ,greg
