Only one pee hole pee'ing
Mudbone
I have a 2002 GTX.
After a long ride this weekend, in the ocean and yes I did beach the ski a couple of times, while cleaning the ski and running fresh water thru it, I noticed that only one of the pee holes is pee'ing.
I assume I picked up some sand and clogged the line.
How do I "unclog" the system.
Thanks in advance.
you can use an air hose, do short bursts and it should unclog....when and if you decide to beach your ski are you shutting it down before it sucks up sand?
are you certain it is clogged? You only need low pressure from the garden hose and sometimes it isn't enough to flow through both holes on mine. Both holes work fine at WOT in the water though.
I assume you mean to blow "backward" into the water outlet?!?!
I did mean to shutdown and coast in, but ran into a small sand bar that I didn't see.
