OK, I checked everything from previous posts. Basically, I could reuse the needle valve 2.0 that the dealer ordered two weeks ago. So I would have to order the carb + part number 75 270500427 ls jet. That would cost me 315.00$ Canadian and of course, with customs, it would cost me something in the vicinity of 375.00$ Canadian dollars total at my door.
Am I missing any parts like gaskets, lube or something?
Between having to re-check timing, check engine for defects or replacing the carb, I have the feeling that replacing the carb first would be the best next move. If with a new carb the ski still has problems, then I would definitely tell the dealer to fix HIS issues, not mine.
As I said, I could probably do that with a friend of mine. It doesn't seem to be that much complicated for him (he already rebuilt a carb for me for a trimmer and he had fixed the issue fast). And he comes to my cottage quite often so we could even test it directly on the lake.
Should I start there because of all the work the dealer did, the only thing not under warranty is the carb?
Thanks.
Benji.
