Hi guys, I have a 99 speedster. Both carbs on both motors have been rebuilt with OEM mikuni rebuild kits and raves have been done by last owner due to the same issue I'm stating now. I then proceeded to redo the left side carb rebuild again with OEM mikuni kits. Once in a blue moon, I'll fire up the boat at home and it will run great on trailer, I then can take it to the water same day and drive it perfectly hitting 40+ mph. Problem is, if I ever idle too low on the left side engine, it will shut off, from there it wont start again, it will just crank no start. If I go days of crank no starting at home, or once in a blue moon if I remove the plugs and crank it without it and reinstall, it will start up then I can take it to the water again and repeat the whole process. Thing is, removing plugs and cranking doesnt always do the trick. I also have a new fuel pump on the driver side. I'm running out of ideas. As of now, its crank no start on driver side engine. I have spark and I have fuel (I assume so because my plugs are wet). Even if I spray carb cleaner, it wont start up EVEN though I have spark. Sometimes, the right side engine will produce the same concern as I'm having on the left side engine. Again, the previous owner had this problem too, therefore led him to replace both rave valves, carb rebuild, and fuel pump rebuild. It was only when I took ownership. I redid the left side carb rebuild with pop off pressures at 38 psi mag and pto, and installed a new fuel pump. Both engines have new fuel lines and oil injection lines, idle 3k out of water, about 1500 rmps in water. I have to keep the idle up on left engine to prevent dying and running into this issue.
