Show me your research......
Do you have any research to support your "opinions"...as to the use of these types oil your referreing too. If so, please copy and paste it and I'll be glad to look over your research. And if I find that what your saying has merit, then you'll be patted on the back as to that research.
But as the moderator of this forum, we do not come in here with information or advice, being shot from the "hip". None of us is perfect and if your snowmobile engine is in fact a "Rotax" engine, your using the TWC 3 oils in it. Then there may be some luck to your good fortune that you've never encountered a problem using any of the oils not recommended by Bombardier. I personally use the "Quick Silver" brand designed as a non TW or NMMA oil in my doo. On the back, it states it's formulated to work with that application. Amsoil is also a maker of the oil, specifically put out to be used in the supercharged 4-TEC engines. If your using anything other than those requirements in your machines, then either the cooler climates have helped out a bit, or you've been very lucky up to this point
But it your basing your opinions totally on experience, then I'd say, opinions are like as*holes, everyone has one.
To my forum readers, your words of "experience" mean nothing to them who have run their Doo's under the requirements that have been set forth in the manuals and the operators hand books.
More than 80% of our members have already gone over this oil issue and for us, it's a closed case. We use the basic requirments set forth by the manafacturer.
You remind me of the type operator who would put the engine oil API designated CF or CD in an engine that requires a designation SE or SF (which is the two different oils for the diesel and gasoline engines. Hey, there both V-8's, so it doesn't matter, right!)
The below is a "copy and paste" from the Amsoil oil requirements, from their website. Please read on, since you obviously want to contiune to debate me. I love a good debate. But I can promise you this, these members will listen to all the mechanics in this forum who have contributed to this debate in the past, rather than someone in here with a cocky attitude that "oh, just use diesel in your tank, that will allow you to use a 75:1 ratio because diesel already has some oiling properties!.......REad on!
While Amsoil does make an oil that is useable in the Bombardier Seadoo watercraft, which has already been established, you must remember, the type for our Doo's is the recommended "Amsoil Interceptor" type oil. Its blend of Non-NMMA, NON TCW standards, with a low ash content make it a good substitute to the "Quick Silver" blend that I use. It's a bit more expensive, so if you go as far as pay the extra price for the AMSOIL, you may as well by the recommended blend of either synthetic or mineral from your local Bombardier manafacturer.
As quoted from the Amsoil companies web site......
AMSOIL INTERCEPTOR Synthetic 2-Cycle Oil is recommended as an injector oil or at a 50:1 mix ratio in carbureted, electronic fuel Injected (EFI) and direct fuel injected (DFI) snowmobiles, personal watercraft, motorcycles, ATVs and jet boats, including, but not limited to, those manufactured by Bombardier®, Yamaha®, Arctic Cat®, Polaris®, Kawasaki®, Suzuki® and Honda®.
There is another 2-cycle blend of Amsoil that will cause engine failure in the typical Rotax engine and that's the TCR series 2000 racing oil. This oil is a TW oil. Do not use it!......REad on
AMSOIL Series 2000 2-Cycle Racing Oil (TCR) is recommended in air- or water-cooled two-cycle motors where NMMA TC-W3, API TC or JASO FC oils are specified. It is excellent for both racing and recreational use in snowmobiles, outboard motors, personal watercraft, motorcycles and ATVs. Series 2000 2-Cycle Racing Oil is not recommended for use with nitro methane or alcohol fuels. It is recommended for use at a 50:1 mix ratio or as an injector oil for both racing and recreation use and for use with catalytic converters.
So Mr. Disappointment, unless you got some real hard core research to bring to this forum, please state your post that "in my opinion" so that our readers will know that this is of the experience of a "sled racer" rather than a PWC water enthuisiast who may be a mechanic, or someone who is versed in the fuel and oil requirements of our specific skis..........from the older 587cc all the way up to the newer 4-stroke 1497ccs......
Thank you for your opinion.....
It's always welcome in the forum!
Louis
SeadooSnipe,
Mechanic too:
Turbines,
Pumps,
Compressors,
All internal combustion engines from:
The single cylinder 18cc engine to
The V-8 427 Big block cu.in.
Motocross racing, street racing
And many other experienced auto sports.
College educated as a Mechanical Engineer,
Licensed and at present
A working engineer at a Chemical plant using Chemical Vapor Deposition reactors.
Hobbies to include building and racing model R/C airplanes and cars.
Boating in my beloved SeaDoo and Tigershark
Oh, and flying kites with my kids!
:reddevil: :rant:
