could be a leak…in the tank…or an oil line…or the pump is set too high…I suspect…an oil leak,,,the leak could even be in the rotary valve,,or.. an inner crank seal…and of course the tank,,,but if there is no oil in the hull,,I would suspect an internal issue.
