I only have 2Basically you should have three lines coming from the oil tank. The two that go to the engine stay, and the smaller line needs to be plugged at the tank. You still need about 1-2 quarts of oil in the tank to keep the lower portion of the engine oiled. When you remove the oil pump from the rotary valve cover, you can install a bypass cover on it, or remove the gear from the pump, and reinstall the pump, and not install a bypass cover.
Here is one from a quick youtube search
https://www.youtube.com/watch?v=hPpCeC0DiNc
The two little small lines on each side of the pump are those are the ones that get pluggedI only have 2![]()
The only thing that fails on these is the little 3/32 oil lines from pump to rv cover and contamination. (water, wrong oils causing sludge, etc) IMO drain the oil tank, purge the lines and rv cavity, replace the oil filter, replace small lines, inspect for leaks and call it a day. Double check the oil pump adjustment. I do it twice a year, or whenever I play with the carbs. The oil cable can stretch over time and set the alignment off.
I am listening and learning too! I will be leaving the pump in place and thanks for the help!!You're wasting your time, I tried to explain the benefits of the oil injection system in an earlier post, and it was ignored.
Lou
