I hope someone can pitch in here, cause I still use the oil injection system. From what I've read here in the forum, you just need to pinch off your carb oil lines and remove the shaft on your oil pump, or block it off. But you have to leave the tank in because if you'll notice on the side of the engine, the large lines are connected to your casing. You can't take them off.
Then do premix in your fuel tank of 40 or 50:1.
There are several threads in the forum for doing this. I've run across quite a few people wanting to do this......
