oils.........
Do not premix the two different oils. If you premix, use the oil in your tank.
To check your pump, read your plugs. If your not oiling, your plugs will show you that. If your not oiling and riding, you'd already know that. If you used half a tank gas and the engine is still running, your oil system is working.
