Oil injection problem
iamgretzky
1995 Seadoo Speedster. 657x. My third motor....first one oil lines disintegrated...rebuilt top end and changed all lines on both motors. Second one...motor came loose from cradle and bent driveshaft etc...fixed. new driveshaft, mount bolts impeller and wear rings ( on both motors) Now have everything ready to go on this engine but am having problems with oil injection. Oil is flowing through the front oil lines but doesn't seem to flow through rear line. (The small one from the pump to the intake.) I can see small amount of air and oil but the the line isn't full like the others. Is it the pump or an air leak or ?. Any help would be appreciated
if you are on 3rd motor I'd say change to premix instead. The oil pump should be bled anytime you remove lines or replace motor and if that wasn't done you could have a failed motor again. Get a repair manual for sure if you don't have one
I fixed it. The small oil feed line had tiny crack and wouldn't hold pressure. Changed it and voila....it filled with oil.
