Oil injection or not
jamdd65
Is there anybody who runs pre mix 50:1? or is it supposed to be 40:1 are you supposed to remove the teflon drive and just let a bit of oil trickle in to the rotary gear and drive. Do you need to re-jet the carb? Is there a kit available to do this with? I know lots of ??s for a newguy. Thnx Jamdd65
I run mine 32:1 since thats the only oil your engine gets. I just took the drive gear off the pump and left the pump on and oil in the tank for rotary valve lubrication. You will use more oil and dmoke more but its good for peace of mind at least. Just my .02
