Oil injection or premix has been a big topic in the forum for quite some time. Whether it's better or not better, depends on who's doing it on what and why you want to......in other words, it's preference.
Dennis and I have been going back and forth with each other in PM and forum post about the pro's and con's on doing away with the injector pump and going to premix. He has made an observation on a specific type of Seadoo engine that I have just been made aware of and I think it warrants users to be aware of this issue. DO NOT ATTEMPT TO DO PREMIX IN THE RFI 787! Without any further research at the moment, I'd also recommend that if your engine runs a fuel injection system, either direct or rotax, this should apply. Rather than explain this, I've copied a PM from Dennis, who is one of our Premium members (and a mechanically smart one at that), who has explained his reason why we shouldn't and I totally agree with his theory. The below is his message to me. Thanks for the valuable insight Dennis!
I'm going to try to explain the problem that occurs if you try to premix a 787RFI. Keep in mind that I totally understand that the rotary gear and shaft still have to have oil and that is why the oil tank (with oil in it)is left in place, so that the rotary shaft and gear, that are inside the cases, still have lubrication. The problem I'm refering to occurs outside the cases at the rotary valve itself. Also keep in mind that a carbureted 787 will NOT experience this problem. Only the RFI 787 will because ,when on premix, the rotary valve (on the outside of the cases) that is being spun by the rotary shaft and gear (inside the cases) will no longer have lubrication because of where the premix enters the engine. With a carb 787 the rotary valve, rotary valve cover, intake manifold and carbs are on the right hand side of the engine. Air and premix(gas and oil) leave the carbs, go thru the intake manifold and rotary valve cover (where the oil injection lines used to be connected) then by the rotary valve (which is spinning in order to time when the air and premix enter the engine) and finally into the engine. The spinning rotary valve is being lubricated by the premix and therefore is not a problem. The problem you run into on the 787RFI is that the premix is not entering on the right side of the engine(where the spinning rotary valve is). The premix is entering on the left hand side of the engine because that is where the fuel injectors are located. This leaves the rotary valve with no lubrication because the only thing going by it as it spins is air from the throttle body(no premix and the oil injection lines have been disconnected). Needless to say the non-lubricated, spinning rotary valve eventually grinds it's way into the cases and ruins the engine.
If I could Dennis, I would have taken credit for this but that's not my nature. I think this was a very good observation and you should get all the credit for writing it. Very informative and I hope those looking to go premix read this post. I fully understand now what we were talking about in PM's. I'm not much into the fuel injection engines but I'm glad we have members in the forum who are!............Good job "Dawg"!........:cheers:
Louis
