I'm really hoping you all can help me out
Two days ago I was out in the middle of the lake enjoying a 90 degree day, working on my tan, pulling some friends around on the wake board.... then all of a sudden I get an overheat alarm. I shut the boat down, take one look inside and said it's time to go home. I had oil/water mix overflowing from the coolant reservoir. Took it home and let it sit for the night. Next day after work first thing I did was check the oil.... low, not even reading on stick. I top it off and turn the boat on. Runs, sounds right, normal. It didn't run long but I checked the oil again to see if I could see water in it... looked clean. Pulled spark plugs, looked good there as well. Drained the "coolant" which looked more like melted chocolate ice cream, drained the oil... looks clean to me. So.... I'm no mechanic but I do have a shit load of common sense.... do I replace the oil cooler? That I already have off the boat? (because I wanted to check o rings) is the oil cooler the issue? And since they apparently don't make that part anymore what do I use to replace it? Help... I'm a fish out of water
