While inspecting my carbon seal i noticed broken wire clips and tie-wraps stuck between my engine and pto!! Along with fiberglass fragments!!
I had the entire engine rebuilt recently including a new crank
Last week i sucked up a tow rope at idle and the shaft was not damaged as the impeller is not grinding on the wear ring and the is no vibration from the engine compartment at all
I need opinions on what to do and potential cause
And it seems my oil line is leaking at the connector in the oil pump
