Sofla
okay.., thi is odd. ent to go start the boat, an 07 180 challenger 215SE, and fresh fro the mechanic, it cranked and cranked and did nothing, but crank that is,t eouldnt fire up. At some point I stopped trying and flicked on a few swirches to turn on some music and a light., I noticed for the first time just then that the running light switch also powered the radio on...? didnt notice it or make the link straight away but I went back to try the key and it dired right up.. Again, not making any connection between them as yet. The next day I went to start the boat and the same thing.., so It dawned on me.., the sequence the day before and I went ahead and flipped the switch again.., and again the radio fired up as did the ignition. So now intruiged I flipped the radio switch on , and suddenlt the radio quit. CLEARLY A SHORT SOMEWHERE, then to the ignition, tried it with switch on ,(the running light switch) and waalaa, fired right up., turned the switch off..., and no radio, no ignition. just cranks and cranks. I suppose its likely right there in the panel at the switches based on the symptos? were it in the harness or the boxes, the link between them wouldnt change if switch were on or off correct?
any experienced and or insightful members please weigh in ... life is hard enough to start bird doggin blindly.
Thaks a pile you all
