Harkins
Just got my 94 xp this year and have been slowly fixing it. New to the Jet Ski thing but am fairly mechanically capable. Finally thought I was good and had it out in the ocean last Sunday. Ran great all day until I was out and it bogged down and eventually stalled. I thought it might have been a fuel issue. So I took it home and checked it out. Turns out the exhaust bolts backed out causing a massive exhaust leak inside the engine bay. With no exhaust pressure the pipes filled up with water and I'm pretty sure made it's way into the engine. I pulled the plugs and turned it over several times to get the water out. Reinstalled the plugs and tried to start it. Shot all of the water left over in the exhaust out but still wouldn't start. I then did a compression check and got 135psi each cylinder. So I'm thinking my next step is to drain the oil and gas tanks and replace with fresh fluids. Sound right? Any thoughts?
