Sportster-2001-951C-Stock
Well I guess I got good news and bad news Lou. I posted the video on a mercruiser forum and the guys there say the clicking noise is normal BUT they claim that even though I ran the engine without water for only 30 seconds that I most likely damaged the sea water pump impeller and I need to open up the lower end and replace it and maybe some seals. Now I've never had my boat in the ocean so I can't figure how any seals might a git in there. Guess there kinda like them damn kudos.
I put the boat in the water today and it ran fine but they are insisting it's a ticking time bomb. Sooo I guess I'll be pulling the boat back out of the water.... What sucks is I got the ear muffs for running the boat on the hose but didn't think I needed them for that short period.
I can't watch your video so I can't hear the sound you're describing but going into reverse or forward you shouldn't experience more than a few clunks if the shift cable is properly adjusted.
As far as the seawater impeller goes, it's always a good idea to change them every few years, but you must do this if engine temp is above normal.
It's actually very easy to change the seawater impeller, place the shifter in forward and the lower housing goes on and off like a breeze.
If you ran it long enough with no water the plastic impeller housing may have melted or might have lost it's shape, so get the kit that includes the housing too, it's not much more and good to have one around anyway.
When you pull off the lower unit, if you want to save your gear oil then shove a golf tee in the hole to keep the oil from draining out of the upper half, don't forget to remove the golf tee though before putting the lower unit on. And make sure the small o-ring is still there, otherwise gear oil will all leak out.
When installing the impeller, oil it with gear oil to make it easier and turn the vertical drive shaft clockwise as you push the impeller housing into place.
Once done, remember to refill the gear oil from the bottom drain plug. I use an impact driver to remove and install the plugs, everyone I know does this, so you're likely to need an impact driver.
A less then 1/2 hour job man, replacing the seawater impeller.
