MxRacer965
Hi all,
Could use some feedback. Ski is a 2000 GTI, 717 and suddenly lost 98% of its thrust.
I was on it with a couple children, the young lady that was driving in front of me was WOT and then shut off entirely, then got back on the gas. When she got back on the gas the engine revved to the limiter, and we got almost no thrust, just a lot of bubbling/cavitation.
I had noticed the day before there was quite a bit of water in the hull, but I didn’t see anything leaking. Skip ahead to when I lost all thrust and when I took the seat off I noticed water leaking in between the carbon seal and the ring it seals against. I tried to start the ski but it didn’t want to turn over, so I assumed something in the drive line bound up...not remembering everything that makes up the drive line I figured a bearing or something initially, no concern the engine seized.
I put the ski on my lift and started researching and instantly came across the carbon ring as a possible culprit. It also had no problem turning over and starting again. When it started I did hear a squeal from the drive line somewhere.
Today I did a little more checking. Put the ski in the water...no leak. Started it up and still just revved and no thrust. I pulled the seat while on the water and compressed the bellows towards the back of the ski and water poured into the hull, but would stop when I let the bellows extend. I then noticed I can very easily compress the bellows a good 1/4”-3/8” with no effort. I had my wife grab the PTO and rotate while I inspected the impeller and it did rotate back and forth.
So...given how easy it was to compress the bellows would it be logical to assume it is sucking in air and causing cavitation? Replace bellows, carbon seal, and ring before anything else? Does it make sense that it would fail so suddenly like it did?
Thanks in advance!
Aaron
Thanks in advance!
Aaron
