1997 gti 720 single carb
changed the carbon seal then tried to start the ski. I did not test before hand as it ran fine 3 weeks prior. When you press the start button you get one loud click and nothing happens. Tried the screw driver trick on the starter solenoid and nothing. Pulled the starter and went connected straight to battery does nothing. Battery was tested and is good. Is the starter bad or just I check something else?
