Floridan surfer
The title pretty much sums it up.
When I plug in my key, I get a long beep, followed by the four short beeps and the check engine light is on. I brought it to a watercraft mechanic who read the codes and advised me that I have a code for DESS post.-Sorry I didn't get the exact code. He suggested that I start by replacing the DESS post, but also advised that it could be the computer or the wiring harness. He did Mention that the computer was doing funny things and at one point, indicated that it looked like it was going bad. It was having trouble communicating with the candoopro.
I have pulled the post and tested it using the following procedure I found on another forum:
DESS Post test
You can test the DESS Post itself with an Ohm Meter and the following procedure:
Check the DESS Post physical connections first.
With the Lanyard off and using the Ohm Meter on the Black Packard connector wires:
Blk wire to Blk/Yellow = Open Circuit
White/Gray wire to terminal on post = 0 Ohm (.7~1.3 Ohms found=OK)
Blk to ring of post = close to 0 Ohm (.6~5.2 Ohms found=OK)
Lanyard on...
Blk to Blk/Yellow = close to 0 Ohm (.6~5.3 Ohms found=OK)
It tested fine. I should also mention that when I plug in the key I can hear the fuel pump kick on which tells me that the reed switches are working.
So then I tried to test the key itself with a ohmmeter. I figured that if the key makes the connection between the button and the ring on the DESS post, I should get some kind of a value on the key itself when I put my test probes on the center metal strip and the metal strips on the wall. The key was open between these two points. Does anyone know if there should be continuity between the two metal strips on the key?
Unfortunately, I do not have a spare key for the boat for testing.I do have another key that is not programmed for the boat and if I plug it in, I get the same exact thing - Long Beep with a check engine light.
Initially I thought the key/computer lost its program, but the mechanic indicated that my key was already programmed to the computer and he also programmed the additional key to the computer. He states that he does not know if the computer accepted the additional key or not due to the communication issues.
Can anyone offer any further guidance for testing before I start throwing money into replacement parts?
DESS Post test
Lanyard on...
