scuba75@gmail.com
Hello and I hope someone can help.
Here is what i have:
1996 GTX with 787 engine
Purchased not running and trying to get it running for my wife. The ski has not been run this year and person I purchased it from said he had it winterized last year and tried to start it oncee with no luck.
First sympton is it has problems cranking. Sometimes will crank sometimes will try and not make it giving one beep and then I have to remove lanyard wait and put it back on.
i have replaced the spark plugs, ignition coil, starter, used another battery that will start up my GP760 fine.
Compression is about 140 on both cylinders
Checked pick up coil, magneto stator, new coil, and spark caps resitance and they are fine.
With plugs removed and grounded using a ignition spark light test system turns over fine and I am getting voltage to the spark lines. So tells me pick up coil DC-CDI coil wires and plug caps are good.
If I crank with plugs removed for a while like i am fixing a flooded engine then reinstall the plugs and useing spark tester, and try to turn over it turns over fine and I get spark voltage.
Repeated this with everything connected as should be and the engine will cough a few times like it wants to start and then I get back into the cycle of it will not crank anymore. I pull the plugs and repeat and same thing. I am now stuck and not sure where to look. Thanks for any help.
