benstoker
Good morning everyone. I know that this is a topic that has been beaten to death on here and I want to start off by apologizing for getting my bat out for this. With that said, I have read (i think) almost every post on here regarding no spark to the plugs on the 787s but I cannot seem to find one that matches. I have a new battery in it that is currently showing 12.45 volts and i have also pulled the magneto cover and checked the stator ohms (1.0 on all 3 wires tests against each other). I also cleaned the pick up coil (there was some metal flake build up on it) and tested the ohms for it as well (257, i think). I have also pulled every connector on it and cleaned with connector cleaner then added a bit of dielectric grease to all of them. New plugs in there as well.
As with the others, it turns over just fine but there is no spark at the plugs. Any thoughts on what I should test next?
Thanks!
-Ben
Thanks!
-Ben
