To add what the DR. said, you also have to be careful not to go to much one way or the other. To small of a leading edge will blaze the prop out of the hole, and to large on the trailing will lug the engines down. Another reason why the OEM`s are a good "compromise".
More importantly after market impellers are far more efficient than OEM`s, also depending on the OEM manufacturer as well...
In the ski`s I`ve also used Skat for short acceleration, tight turning and close water conditions, as they tend to run out sooner with less top end mph, but get you from turn to turn quickly.
I`ve run the solas for more open water where faster cruising speeds are constant for a longer range, but they aren`t as tight down low.
All these impellers can be tweeked, "kicking" the trailing edge for + or - rpm`s. and also the leading edge for conditions.
Hub designs are what gives these impellers different characteristics. Yamaha had a small hub pump, early design, and switched to a large hub pump and impeller when the 1300 arrived. currently there are many known great combinations that work depending on what you want to achieve and what mods support the overall torque so the machine has the ability to turn a steeper pitch...
fundamentally, using the OEM pitch numbers are a starting point. discussing what your needs are with the impeller company is key...
Do this long enough and you`ll get to distinguish how each impeller "feels" and what to expect without any guess work...
good luck!...
