No power with good battery
Boondox
I’m not receiving any power to my 2017 gti se 130. Battery is good, swapped it into my other one and started right up. Fuses are good as well. 34 hours on fresh water. No beep,display, or spooling noise when start is pushed. I’ve been told to check the connection’s, but ground cable looks to run to underside of engine. All look super clean though. Would be difficult to tow to ramp, so trying to trouble shoot on the Dock.
TIA for any thoughts.
30 amp relay in the fuse box is probably stuck open, pretty common relay available at most auto parts stores. You should feel it click closed when you turn on power.
I have a 2012 SeaDoo RXT 260 IS. Having an intermittent issue, powers up starts and runs fine. If leave on lift without cover and it rains it will not power up, nothing gauges don't light up. If I leave it in the sun back deck open it works fine after day or two in the sun. Has anybody ran in to this issue? Seems like moisture is causing issue but I would like to eliminate the problem.
Thanks for any insights, Tim
Battery connections, 30 amp relay connections, corroded grounds, wires, or connections. Pull all your fuses and relays and spray all connections with electronic cleaner. When it’s dead check if you have power to the relay in the fuse box when you push the button, if you do it’s probably the relay. If you don’t it’s battery or start button related including all wires and connections. Make sure your start button rubber cover is not ripped and is sealing properly.
My 2017 Spark 2UP came up DEAD 2 weeks ago...good battery, etc....turned out to be the relay in the fuse box....bought 2 on Amazon for $20.00...problem solved, I'd start there, as well.
30a relay fixed it. Thanks for the response!
That was it. Replaced relay and all good. Thank you!
