Hook It Up
Mikuni Carb won't pop off. Just holds air until the plugs fly off
What is the carburetor off of, what pressure do you make it up to before the plugs come offMikuni Carb won't pop off. Just holds air until the plugs fly off
Thinking it was the problemThe spring affects the pop off pressure, do you know what the pop off should be with the old and new spring? I’m not familiar with Yamaha but that seems awfully high. Why did you change from the original spring?
Should be 55psiThe spring affects the pop off pressure, do you know what the pop off should be with the old and new spring? I’m not familiar with Yamaha but that seems awfully high. Why did you change from the original spring?
Wish I could help, but I can’t think why, hopefully someone else like @mikidymac might have an ideaCleaned it, tried different springs, still no pop
Where is it hissing from? Have a look at Mikidymac’s carb rebuild thread, you can find it in his profile. Maybe send a picture of your set up for the pop off test,Put in new needle and seat, original spring and now it hisses at 25psi, no pop
