Hi everyone, I wonder if you can help?
I have a challenger 2000 with the merc 240EFI, the earlier model with the stator.
I have a good blue spark, 36psi on the fuel pressure, I can hear the lift pump and high pressure pump working but I have bone dry plugs? It doesn't even try to start.
The problem occurred last week, the fuel pumps were not turning on, that turned out to be a bad wire in the harness (pin 11), the red yellow to the solenoid. I replaced it as well as the earth pin 16.
I checked all 16 wires in the harness and they are now all good. I took the manifold off and the injectors all read the same resistance I also preformed the test in the manual. The injectors seem clean and functioning. I had also replaced the ECU the week before so I know that's good. What could I have done in replacing those two wires that is stopping fuel delivery? I seem to have fuel all the way to the rail.
Oh and I also checked the compression it was 105psi on all cylinders. I know that's low but I'm hoping that's because it's cold or a bad gauge as they where all balanced and it was running ok before.
Thanks in advance
Alan
Thanks in advance
Alan
